I know many of you have waited for a modded firmware for the Philips 5982, so here it is. Its from a Brazillian guy by the name Ryan Jefferson. Portuguese is not my native language, so sorry for the rough translation.
Main features of this firmware is 40 character filename and great subtitle support.
Download:
http://www.portabellos.ca/download/DVP5982_37_v0.4.rar
Same as above but with USB Long Filename and NO HDMI
http://www.portabellos.ca/download/D....4_NO_HDMI.rar
Changelog
v0.1 February 22, 2008
Choose the vertical position of the legend by ISO setup
Up to eight sources for subtitles ISO selectable using setup
Color legend ISO selectable using setup (yellow or white)
Sources for captions with contour
Removing the transparent background of subtitles
Eight lines in the browser (were four)
New source for the browser
Names in the browser long with up to 45 characters (only loader)
Arrows philips hidden when scrollbar is activated
New icons - by Laza Dezign
New source for the directory lines with contour
New source for MP3 tags, with contour
Correction of the problem of firmware Philips requiring sources with color "special" to get rid of transparency. This firmware any source "normal" serve
More characters (40) in directory browser(DVD)
GOTO function for MPEG4
v0.1a February 22, 2008
Correction of Subtitle Timing Bug
Character Filter - Now letters marked appear in the browser
v0.1b February 22, 2008
Now with automatic loading of external subtitles, using the "method RafaLibrenz", which is a simplification of the method developed by Hej456 and explained in its document Smart loading of text subtitles in RISC DMF's.
v0.2 February 25, 2008
New option for vertical alignment of ISO captions: "Top" or "Bottom"
10 to 16 pixels between the increment options. This will give more freedom of placement of the subtitles, but you must be aware that certain combinations of source / position / TV legend will disappear or be cut.
v0.2a February 25, 2008
Now the phrase "ISO Subtitles Setup" finally appears at the top of the menu thats created
Two sources who were not good for two with shade
Reorganized the sources more or less by size
v0.3 February 25, 2008
The new menu now supports OSD in Portuguese or Spanish as well. In the case of Spanish texts, I also put in Brazilian Portuguese (because I do not know lhufas of Spanish, of course).
New icons for the menus and subtitles in Video Setup
New definition of colours for the Setup. Now it is easier to read as the original
New images of background. I am still testing the contrast.
v0.3a March 1, 2008
Contour activated at the source browser
Contour turned in MP3 tags
Messages key "Karaoke" redirected to the top of the screen
v0.3b March 8, 2008
The image of an image browser by PAL, which should eliminate the problem that occurs with whom uses upscale. In theory it should not appear to have more black bars.
Retired the name "DVP5980" of the original image, as the firmware being used also is the DVP5982.
v0.4 May 25, 2008
Added the capability to use USB Long Filename with 23 characters. This DISABLES HDMI!!. Please choose the correct file
Removed file extension in browser using USB
Results 1 to 30 of 35
Anyone know if there is a way to get long filenames with USB?
Has anyone tried this out yet. Does anyone know if it really works & won't screw up your machine.
shadow_cruiser did you try ?
btw I downloaded the file.the wordpad is in english
I will try tomorrow if I can find a blank CDOriginally Posted by dfisher052
.SUX you can't use the USB to update the player like the OPPO
I tried it and it works just fine. The only problem that I've seen with it is that when you read off the hard drive or usb you can't use long filenames.
thanx for the info.no need to update since it doesn't solve the USB long filename
subtitle become blinking after updating. feel tired watching
Not able to download the bin from this site.
Please advise.
Bala
Originally Posted by shadow_cruiser
Very difficult to load this file from the site you mentioned.
Can you please up load the same in this forum download .
Thanks,
Bala
Yep, the link is dead. Can somebody post the file somewhere a little more permanent?
Sorry about that guys. My partner who also has access to the server deleted it by accident and didn't tell me. I have many files being hosted there and didn't notice. The original post has been updated with the final version and I also add the version where you have 23 Characters through USB but it disables HDMI. Have fun!
Great job! Love the look of it. Long file names are great and very readable; very nice subtitles - finally readable and without the awful gray background. Haven't tried the USB version, since I hardly ever use my USB stick in the player ... and someday may need HDMI.
Noticed a few problems though:
Cannot find the GOTO function for MPEG4 files. How do you use it?
Don't like the new automatic loading of subtitles for MPEG4. Can you make that an option in the setup?
Logos on background screen, at bottom (like the DivX logo), are half hidden below the bottom of the TV screen (on standard 4:3 NTSC television), bottom part lost in the overscan area.
When using the <Next> and <Previous> buttons in the browser to go back or forward by full page in filename lists, the screen still only moves by the original 4 lines at a time, instead of the 8 lines that are now visible (for example, necessary to press <Next> two times to get to the top of the next page).
Finally, a Feature Request: The one thing still badly needed is STILL/FRAME-BY-FRAME advance for MPEG4 videos. Drives me crazy that you can pause a DVD movie and advance by one frame at a time but you can't do it with DivX/MPEG2 videos. The same button (down arrow) that does it in DVDs just gives "prohibited" symbol in MPEG4s. So it's almost impossible to examine any individual frame in MPEG4s. Maybe this is a flaw in the player that can't be fixed in firmware, but is it possible to look into it?
Otherwise, like I said, this is a terrific job. Keep up the good work!
You can always apply the NON-HDMI firmware to retain USB long filename and then apply HDMI firmware when you need it later on.
To use the GOTO function, press the title button twice and it will come up. Remember when using USB with GOTO, it takes about 5 seconds to jump where you want to go. Maybe longer if your using a slow flash drive.
The automatic loading of subtitles cannot be added through the menu from what I know. My buddy of mine is the one that modifies these firmwares, I'll ask if he can add a menu option for this. He hasn't worked on firmwares for awhile due to work as this was supposed to be his final firmware.
Have you had the cropping problem before?. I have this problem too as it doesn't happen with my other LG player. I didn't really care much as only a little bit get cuts off. I'll inquire about this.
I inquired about this awhile ago and you can only jump 4 titles at a time, such a shame. I will ask again, maybe he has learned something new.
Frame by Frame is impossible with this player and DivX videos. Its a flaw in the original firmware itself because my LG can do this.
I'll let you know what he says
Thanks for the feedback.
I'm looking for a few more people to test out a new firmware before its released. Its been tested on my player and works perfect, just need a few other users to give me feedback. This is only for 5982 users. Please PM me if interested.
Here are the features:
* 46 character filenames, in the Disk browser.
* 23 character filenames in the USB browser (NO_HDMI ONLY)
* GOTO function by pressing the TITLE button twice
* File extensions trimmed
* The arrows on the browser were replaced by a scroll bar
* Disabled image preview
* Max 40 characters on the folder name bar
* Repeat keys replaced with Volume control keys
* Changed some colors in the filebrowser so you can see the file names better
* Subtitles are shown from the bottom of the TV screen with up to 4 lines
* You can now select the subtitle font from the menu
* WordWrap + Reformat for subtitles
* Added a new font for filebrowser (white outlined with black)
* "info panel" (top of filebrowser) have white characters outlined with black
* Color selection bar
* New icons for filebrowser
* new graphic icons
* 44 characters for the directory folder names
* Fixed "1 sec. srt bug"
* More than 42 characters for subtitles names to be loaded
* New menu called: "DVD Quick Play" in Setup
* New menu called: "Subtitles Loading" in Preferences
Any ideas why this firmware might completely disable my USB port??
After updating to this version, all works well (although the volume level is about 50%, for some reason)... except that no matter what device I plug into the USB port (I have several that previously worked fine) I get nothing at all available. It doesn't even say "device not supported", it just doesn't even attempt to read them. Needless to say, I've tried to press the remote's USB input button without success, and I can't find any options in the setup that might be causing the problem.
I have no idea why it did that. This has worked on thousands of players. Ryan Jefferson has released many firmware files and is a veteran at doing it. Needless to say, we need to solve your problem.
What method of updating did you use?
What model player do you have?
Which file did you choose?
Does the DVD player even recognize the USB port?
It's not a big deal, I was merely experimenting and I'm sure this firmware works perfectly when used as intended. In case you are interested what I was playing at, read on.Originally Posted by shadow_cruiser
My player is the DVP5960/37. I read on a few forums (softpedia, etc.) that the 5980/5982 firmware would partially work on this model to get long filenames working with USB devices, so first I tried a 5980/12 modded firmware. Of course, this first firmware caused chaos being set for PAL televisions and all, but I managed to change the options despite the crazy flickering purple screen and it seemed to work okay. Naturally, it wasn't really okay, and although it played video perfectly it produced no sound whatsoever. A bit strange, I thought, but obviously the player can use the 5980 firmware in some manner.
So, I updated it to the one here (5982/37 v0.4 no HDMI with long USB file names) in the hopes that - being for North America this time - I'd have some success. Alas, you saw my problem. The setup screen and options worked perfectly (although sound - now working - was at a level of about 50%), but the USB port was not recognized at all. I tried several devices that previously worked, but nothing happened. It didn't attempt to read them and I didn't even get a "device not supported" message.
Oh well, them's the breaks.
I re-energized my player with my old modified 5960 firmware. If only someone could come up with the long filename support on USB devices...
Thanks for the update.
Why does long filename for USB not work with HDMI out?
I am testing on DVP5990. firmware 31 from Philips sorts data files by descending file size, not name!
(edit: that seems incorrect, it seems to do 8.3 sorting. FolderSort http://www.jetman.dircon.co.uk/software/foldersort.html should help.)
Is it possible to replace the packaged background images with our own?
Is it possible to release this as modded 5990 firmware to retain WMV and WMA for the 5990/5992?
@pbush77 - Have you checked the divxpert forum?. vb6rocod has a nice modded firmware for the 5960.
@FredThompson - In order for long filename to work, you have to replace the ARM core with that of the 5960, thus, disabling HDMI out. There's no workaround for this.
Yes, its possible with MtkReplacer. Though the backgrounds have to converted to .mpg format using tmpgenc or something similar.
Its possible and hopefully will happen soon. I've asked the developers but nobody wants to mod it as its a new player. The developers usually mod players that they own and until that happens, we won't be seeing anything soon. I've started modding the firmware myself doing the easy modifications. Work is keeping me busy so I don't have much time.
It just seems odd to me that the long filename routine from the disc source couldn't be reused.
I found something odd with the 5990 and PAL DivX on NTSC: Aspect ratio is screwed up. The TV (widescreen) has to be set for fill mode to get proper 4:3 display. Don't know if this is true of previous models.
Would you let me try your beta 5982 firmware on my 5990?
PAL DivX as in 25fps?. I have many 25fps movies in XviD format and they play fine on my 5982.Originally Posted by FredThompson
I have stopped modifying the firmware myself since now the veteran philips hacker vb6corod, has taken it over. He knows much much more than me
. We should be seeing a new 5990 firmware soon. Don't expect 23 characters on USB though.
Yup, 25 fps PAL DivX. I'll certainly supply one as a test source if anyone is really interested.
Some form of jukebox shuffle for audio playback would be really nice. Wonder if the firmware has playlist support. Didn't see a mention in the user manual.
Realized last night that FAT filenames are different than ISO from discs. Still, it would seem the only things to limit USB filename lengths would be counters or buffer space. Then again, that's said without any inspection of the code.
Thanks for the news about modded 5990 firmware.
Have to ask.. (as this is very interesting) I semi-retired my 5982 when I got my 5520H (recorder). That solved some of the problems of 5982, longish filenames but one big bugbear for me is no support for mpg files on data disc.
Any one working on a modded firmware for these(5520,5570), or even thinking about it? Different backgrounds alone would be nice..
This mod doesn't work on Uk 5980 .. probably because its bin file should be 5980_12.bin .(24.08.08)
I am not sure it would work? I don't need all the subtitle mods (or HDMI) atm but the long file names length would be
great.
THis Pizza's got onions on it! I said NO onions!
The electronic components of the power part adopted a lot of Rubycons.
Excellent firmware! Thank you.
I have a request. Starting with the 5982, Philips disabled the ability to change the Video Setup Page->TV Type to PAL or MULTI. NTSC is the only value possible now. Can you mod the firmware to allow choosing of PAL or MULTI?
I want to take my 5982/37 player to Europe with me and it will be very useful to be able to set it to play on PAL TVs.
Hi I don't understand, your firmware is super, why do you stop the support?Originally Posted by shadow_cruiser
vb6corod has been moding the 5990 but it doesn't fit on 5982
I just want to say THANK YOU!! I've been waiting for the long filename support since I bought the DVP2982 last year.
I have two DVP5982's at home. I flashed both with the new firmware without any problem using a burnt CD. One of the 5982 attaches to a USB harddrive with 300+ Divx movies. This firmware makes it so much easier to browse through the movies. Everything works great so far. Now I can see most of the movie names and eight lines per screen. Subtitle support is excellent with selectable fonts, color and position.
It would be perfect if we can retain the HDMI port
anyone have the link to d/l the firm for the 5982, since the original link is not working.
thanks
[Release] Philips 5990/12 modded firmware by vb6
By shadow_cruiser in forum DVD & Blu-ray PlayersReplies: 138Last Post: 28th Sep 2010, 18:12 -
[Release] Philips 5982 Modded Firmware v0.4 (w/USB Long Filename!)
By shadow_cruiser in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Jul 2008, 05:12 -
Philips 5982 and USB
By chits007 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 26th Dec 2007, 08:43 -
philips 5982 with a better remote possible?
By wkk in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Sep 2007, 22:32 -
Philips 5982 firmware to support more then 8 characters
By elec999 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Sep 2007, 11:27
